996 Turbo Forum 1999-2005
What model Uniden Bearcat should I choose?
Old 04-14-2004, 11:57 PM
matterhorn762
matterhorn762's Avatar
Brian, got your PM. Thanks! Take it easy in the Explorer.
Can somebody tell me if an external speaker is required for the BCT-7 or BCT-8? I don't see a speaker opening in any of the pictures.
Old 04-15-2004, 03:29 AM
David in LA
David in LA's Avatar
no external speaker is required
Old 04-15-2004, 11:27 AM
GreggT
GreggT's Avatar
Just my opin but combo of the Uniden and a Val 1 are excellent........as always, both should auto power up w/ignition.
Old 04-15-2004, 02:07 PM
washington951
washington951's Avatar
matterhorn - no external speaker REQUIRED on the 12 - there is one on the bottom of the unit - but its pretty low, especially if you have any exhaust mods. it would be an easy addition as there is a mini jack on the left side of the unit for the addition of an external speaker if desired.
i just finished mounting my 12 yesterday. on my 951 it sits just outboard of my left knee - velcro'd on the lower, left dash knee pad area. easy to run power and i also used the optional wire antenna - ran it up the weather stripping of the drivers door - seems to receive MUCH better than if using the small, rubber antenna. i'll use that on the explorer or rig a better external antenna and hardwire it as well. its a regular BNC jack.
Old 04-15-2004, 04:32 PM
matterhorn762
I've just purchased the Uniden BCT-8. I'm going to try to fit it in the current CD-holder slot. It's about .05 inches too tall, but we'll see how it works.
Old 04-24-2004, 09:13 PM
matterhorn762
I got the Uniden BCT-8 scanner installed yesterday. I had a hole carved out from the top of the empty compartment directly beneath the speaker of the scanner (which is on its bottom). Therefore the natural open consol slot acts as a conduit for the speaker. Sounds pretty good.
Old 04-24-2004, 09:14 PM
matterhorn762
Default close up
And here's a close up
Quick Reply: What model Uniden Bearcat should I choose?
