My car has travelled 105,000 miles and I suspect my engine mount(s) needs replacing. Other local 996TT have level exhaust tips, whereas mine are not level. Is this a sure sign a mount has gone?
The best way to determine if the mount is gone is to look at them from underneath the car. If you see black fluid stains on the side, then they are bad. Factory mounts are fluid filled and this is the tell-tale sign.
