996 Turbo Forum 1999-2005
clutch again?
Old 07-30-2014, 07:25 AM
Mabbott
Mabbott's Avatar
Default clutch again?
Just dumped 5,000 on a complete clutch rebuild about 6 weeks ago all done by the Porsche dealership.
Noticed today that the clutch was pushing in softer than normal engages clutch through all gears fine but not until the clutch pedal fully depressed instead of around three quarters and on clutch pedal release clutch does not grab as strong.
Any ideas....im thinking air in the line or something with master cylinder...clutch just has faintly to much give and not as much bite. drove fine yesterday.
Also has clutch slave seal replaced right before the entire clutch burned out. same Porsche dealer.
Once clutch was rebuilt certified mechanic test drove and sighned off...should this be under warranty for the work just done?
Any ideas as to what it might be?
Thanks in advance.
Quick Reply: clutch again?
