headers!!!
headers!!!
Hi guys,
I bought some used fabspeed gen 1 headers.
Looking at them and matching them up to the gasket, they seem to not match up. That is, when you line up the bolt holes, one edge of the gasket overlaps the manifold opening(lengthwise) by about an eight or 3 mm. If it hangs into the gas flow it could be disruptive. Looking at the marks on the header faces, it seems to be the way the gasket was fitted in the past also.
Not sure, if this is normal but I'm worried, that these headers don't line up with the head exhaust ports perfectly and if I install them I'm going to lose power.
A) Has anyone fitted these headers and had an improvement?
B) Do the stock headers do the same???
C) Am I better off keeping the stock headers installed??
I'm aware the fabpeed website claims some gains, which is why I bought them, however I don't want to remove the stock headers and go backwards.
Any thoughts guys?
Many thanks,
Loui.
Any thoughts guys?
Many thanks,
Loui.
Thanks for the responses guys. I think I wasted my money on these headers. Will stay stock and maybe port match and polish in the future. Can't wait for the umw flash though!!!
Lots of poor header designs out there for the TT cars. The Fabspeed arent the worst, but quality sounds like its an issue. If you want more power or a bit better response aftermarket headers can help, but it takes buying a proper set.
