Tire size and spacer help please
Trying to help out a friend here. He is buying my set of BBS e88's. The specs of the wheels are 19 x 9 et50 and 19 x 12 et64. I know the fronts will bolt on just fine. For the rears, what is the ideal offset for a 996tt with a 12 inch wheel? ET 45ish? His car is stock ride height, he does bring it to the track every now and again. What would be the recommended tire sizes for this set up?
Thanks for any help
Thanks for any help
+64 is no good, if he did +30 to say +40ish he'd be good.
Tell your friend to rebuild the rears because they won't fit
Adding a spacer makes the offset lower, not higher. So adding a 20mm spacer would bring the et64 to a final et of 44. Is ET44 a good offset for a 12" wheel on a 996tt?
I think a final offset of 40-51 would fit. Yes the spacer does decrease the offset. That's why we can run narrow body wheels with spacers and they can't run our wheels because they stick out to much.
Found some good info from the Tire rack guys
19 x 9 ET 50 - OK
19 x 12 ET64 w/ 17mm spacer - Final ET 47 - OK
Tire size for 19/9 and 19/12 - 235/35 and 315/25 Michelin PSS.
Look ok?
19 x 9 ET 50 - OK
Look ok?
Yes that looks ok. Not sure about stock height but I have it lowered and need to bend some plastic wheel liner back with a heat gun to get the 315's to fit. Though at stock height they may not be a problem and you really could push out the wheel as much as you want.
Thanks! Would it be better to run 245/35 and 305/30 Michelin PSS. At stock height if he ran a 20mm spacer for a final et of 44, would this be ok?
Stock offset is 45 on 11" wheels and people put 5-7mm spacers on stock wheels so 38 offset. So yah I think 44 is np. For 19" 235/35 315/25 is perfect I run 18" 235/40 315/30
The wheel will stick out. Nothing like owning a super nice set of wheels and putting them on ghetto like. Redo the rears, do it properly, please.
[url=https://flic.kr/p/nTLbUc]
[url=https://flic.kr/p/od49Zn]
lets see the rear view of them
