996TT Wheel Stud Conversion Kit
Former Vendor
RacingBrake offers wheel stud conversion kits for quick and easy wheel/rotor installations.
Instead of taking on and off the hub bolts, RB conversion bolts bolt onto the spindle and stay on for good once torqued. Acting like a traditional wheel studded spindle.
M14x1.5 Porsche Conversion Studs
RB wheel studs are made of alloy steel, heat treated, and certified to SAE 10.9 class. They feature an 8mm hex head for easy installation and replacement.
wheel nuts are made of alloy steel, with chrome plating for an attractive and lasting finish.
Thread Spec: M14x1.5
Length: 80mm (3.15")
Proof Load: 830 MPa (120,000 psi)
Tensile Strength: 1,040 MPa (151,000 psi)
Installation: Torque studs to 40-50 ft-lbs.
are this weather resistant?
Choose your studs wisely. Lots of failures out there too, more so than with OEM bolts. With that said, I've always had studs on my car without issues. Knock on wood... $10 for a quality stud & nut is about right btw..
having some lug bolt issues. need option(s). TIA.
john this sh*t's killin me here. what is your recommendation running f'star 18's ( though keepin my eyes/ears open for some possible ccw's ) that need that ridiculous "ring" to fit the hub.
Former Vendor
Our wheel stud conversion bolts are designed to thread into your spindle and stay on for good once torqued.
Before
After
with the nuts supplied,
you then only remove/reinstall the nuts when removing your wheels.
Eliminating the use of Lug Bolts.
the nuts shown are not correct for Porsche wheels...should be ball-seat not cone.
I'm not very familiar with Forgestar other than the fact they are not "forged" so the name is a misnomer. I believe they are cast in the US from Asian (Chinese perhaps?) material. Since the lug bolts are unique to the wheels, I'd be willing to bet they are Chinese also, hence the quality issues you are seeing. I personally would not run any wheels that I could not run with OEM lugbolts or a good quality set of German made TUV studs. If I could not run a top quality set of wheels bolts or studs, I'd go with different wheels. A wheel flying off due to hardware failure is not acceptable. Too much at stake. That's just me.
Former Vendor
lot more homework to do. and i glanced at the h&r stuff. it's gettin complicated ( for me.. ) but thanks again for the advice.
