Mafless setup - Can u run Forge DV's?
I currently have forge DV's and I am going to a mafless setup. Can I run the forge DV's I currently have and or do I need to go to something that vents to atmosphere.
so maybe have the DV's vent to atmosphere? Or you need BOV's? Or can I just keep it the way it is and run a mafless setup?
Tials
if the plumbing is easy enough, I'd keep the DV's and recirc. but knowing the way most MAF-less setups are, it'll be easier to use blow-offs..
