996TT w/ EVOMS airbox - safe to drive in the rain?
So I left my 996tt out the other night and it rained. The next day I popped the trunk to change my reverse bulbs over to LEDs and I noticed about 1" of water standing in the EVOMS airbox. I used a towel and sopped up the water and the car started and ran without issue. Is hydro lock a common issue with this mod and these cars or would the air filter need to be mostly submerged before this would really be of any concern. If the car could have sucked up water and failed then is driving these in the rain really dangerous as well?
mine has a EVOMS airbox, haven't noticed a water build up issue, haven't looked but maybe there a drain hole that is plugged? If no drain-holes, crack out a 1/4" drill bit and make one...
I'll look at mine tomorrow.
one thing mine does have is a hydro shield, if that means anything...have been tempted to go back to a stock airbox/filter setup...
just looked at mine, appears to have ~1/4 hole in right side of box in the lower 'channel', hard to tell if it came that way or drilled afterwards...
I think I'll drill one in the 'channel' as well then. Is there anything important directly under the airbox (I'm relatively new to the platform, and didn't install the box myself).
safer to just pull the whole unit out, only the one bolt(13mm IIRC) and the clamp at the MAF tube.
Former Sponsor
There should be a pair of holes in the drain channel at the back of the bottom of the airbox. If it's been in there a while they may be plugged with dirt, and there are a small number of airboxes out there from a number of years back that did not get the holes added before shipment (for the past several years, we switched to having the holes molded into the airboxs in production). The holes do their job; we've never had any reports of water ingestion issues with these intakes.
As far as removing the intake, there's a decent power loss to be had by going back to stock on a modified car:
