Good feeling gone ... 996 turbo oil leaks
That "quote" came out strange ... still learning how to use this site. Thanks all for helpful thoughts ... and will stop sweating the oil ....
Swung by P Dealer today and service advisor saw above picture and said he sees this a lot on turbos ... recommended as did thomapa1 and others that I put a few hundred more miles on it before they check it out. Given that it didn't get a lot of drive time in past year, said things could seal up a bit and thought that 5W oil that was put in will help. Said if there is a leak it could be 3-5k in work ... not great, but not end of the world.
Good feeling coming back!!! Thx all.
Good thing to keep in mind, if you run your TT hard make sure you wait in a idle state for no less than 1 minute before turning the car off. This allows the oil flow over the turbo bearing to cool down the bearing and prolong the seals. Even if I run the car at non hard driving speeds I wait a little bit before turning the car off.
The cold startup smoke issue at times is due to the configuration of the metzer engine as a flat six.
