60-130 for stock 996 Turbo and Flash only 996 turbo?
I am aware of the "list" that exists but I am looking specifically for 60-130 times for stock 996 turbos and ones with just a flash (exhaust is ok too). Please post up your times if you have them.
Thanks!!
Thanks!!
K16 car with catless exhaust, GT2RS intercoolers, Cobb MAFless custom tune from Sam at By Design and 100 octane, 4th gear only, 8.76s 60-130.
Only data I can find readily from my car right now. Could be better with starting in 3rd and shifting to 4th, not sure. Clutch slipping so had to dial the power back to pump gas.
That is very fast, and you might do a tiny bit better with a 3-4 shift but, I suppose that you have lots of torque so not needing to shift might actually/also give a better time. Some say it doesn't do much of a difference. Shifting does however always add time.
I'm in Europe so I use the 100-200 km/h and I have a 8.8 sec run when the car was bone stock. I forgot to put the 60-130 mph units in my racelogic box that day. Usually, 100-200 km/h is 1-1.5 seconds off the 60-130 mph run.
Im gone do some runs as soon as weather gets warmer, at least having somewhere around 75 degrees. I have since the stock run added a 3" Speedtech exhaust and want to know if my buttdyno is correct, that the car is a tiny bit faster than stock. I think I can take off 0.2-0.5 sec. After that, a tune and test again.
Originally Posted by Dock
I'd suggest the thread starter check 6Speed for data on 60-130, but his post here is almost 3.5 yers old and he may not even own a 996 Turbo any longer. 6Speed has a 60-130 times list.
Reason why I posted here is because I had the same question and didn't wanna do a new thread about the same thing.
