Question on dealer service prices: Is this dealer trying to take owners for a ride?
Hi All,
Have been thinking about a couple of upgrades/modifications for my 2003 996 Turbo (purchased a year a go CPO with 15K miles, have since flashed the UMW).
Planned upgrades include PSS10 suspension, GT3 Shifter and modifications include replacing the yellow fender lights with EU smoke version.
So I went to my local dealer, New Country Porsche of Greenwich, CT, to inquire about how much they'd charge to do an oil change and install the above.
Here is what they said:
$560 for 15K mile service (I have 20K miles on the car, and this service includes change, air (including pollen?) and oil filters, and multipoint inspection)
$1,400 PSS10 Install (excluding alignment, which is another $289.95; dealer represented that it takes 8 hours to perform this install without the alignment.
$700 to GT3 Shifter Install (dealer represented it takes 4 hours to perform this)
Now I'm not cheap and happy to pay a fair price if it really takes that much time, but the above times and prices seem a bit much, especially since the dealer is trying to get more service business from people looking to modify their cars. I mean when I first went there and inquired about the shifter install, the service manager's reflexive response was 3 hours----as in, if you want us to do anything in this shop, you'll be paying a minimum of 3 hours time---before he checked with the mechanic and came back with 4 hours.
Can anyone please advise on whether the above is reasonable, and if not, whether there are any reputable independent contractors in Fairfield County, Connecticut or Westchester, NY?
Also, any other service replacements I should be thinking about in light that it's a 2003 with 20K miles and UMW tune? Plugs. coil packs, diverter valves?
Any thoughts or advice would be much appreciated.
The shifter installation takes less than an hour.
Hopefully, someone local to you will recommend a good indy in your area. If not, start a new thread with this as the title:
"Looking for a good indy shop in the Fairfield County, Connecticut or Westchester, NY area"
RAC (formerly Ruf), where I get my stuff done, charges the following (working from memory):
Oil change = $189
Alignment = $169
Shifter install (I just did this) = $150 (dealer wanted $400)
Not sure about the suspension work, but so far I have found that the local dealers basically charge twice what RAC is charging. Don't know how they get it - maybe if there were no alternatives, but that's not the case around here. Hopefully you can find a good indy.
Oil change = $189
Alignment = $169
Hey Bro,
Greenwich CT is Deep Pockets country. Hedge Fund heaven. The very last place to go for fair pricing
for any high end car service.
Dan Jacobs (Hairy Dog Garage) in Oxford is top notch and most reasonable. About 40 minute
drive but you and your turbo will be delighted. I know I was!
At ten years old I'd do the equivalent of a major 60K service and establish yourself a solid base line. Change all fluids such as coolant, gear oils, motor oil and brake fluid plus do the plugs, coil packs, all filters including fuel filter and maybe the serpentine belt. I can't help you on the cost of these as I DYI them but save yourself a ton of money and find an indie. Those quoted prices are exorbitant!
you shouldn't ( need ) to do that before 30k. dv's only as needed; or for perfomance gains or should they fail. cheap to replace.
Thanks much for the insights everyone. Appreciate it, and will check out the local indie's around here starting with Dan Jacobs. Like the idea of doing the 60K service to get a solid baseline and will price that out and advise on what I learn...
