Acceptable Non-OE Tire Sizes for AWD?
I'm thinking of buying wider 9" front wheels and stepping up the tire width, but I know the AWD requires similar circumference on front & rear.
But what I don't know... What is the acceptable difference in circumference to avoid differential damage?
The stock 225/40-18 and 295/30-18 are within 0.5%.
245/35-18 and 295/30-18 are within 0.9%. Is this okay? Anyone run this set-up with AWD?
Thanks for the help.
Spec Sidewall Radius Diameter Circum Revs/Mile Difference
225/40-18 3.5in 12.5in 25.1in 78.8in 804 0.0%
235/40-18 3.7in 12.7in 25.4in 79.8in 794 1.3%
295/30-18 3.5in 12.5in 25.0in 78.4in 808 0.0%
315/30-18 3.7in 12.7in 25.4in 79.9in 793 1.9%
the 315 has a diameter of 25.5". The 295-30 is 25.1" the 235- has 25.4", and the 225-40 is 25.1"
this is the only set of specs i still have/use. there was a very comprehensive thread/spreadsheet for all compatible pcar tire size/offsets incl rev per mile differences, but i'm unable to find it. sorry. you might find it with a search
Only problem with going with 235/40/18, 315/30/18 combo is that there are no R compound tires. I stay with stock becuase I can run MS PS cups which provide way more grip then putting on wider tires.
Nitto NT01s come in this size. I've been running this size on 9/12" wheels for several years. Probably the best bang for the buck R compound out there. Good to the cords..
Thanks, I am going to start doing the same. The tires sound like they can stand more heat cycles and they are wider then the cups.
Unlike the Cups, heat cycles are not an issue on the Nittos. They're good to the cords. I'm switching NT01 sizes to 245/40/18 and 305/35/18, obviously not an AWD set up. Just ordered 2 sets. $912 per set out the door...
What offset are you running on the 12" rears? Tried them on the stock 11" and they don't work. Also did you roll the fenders?
I run the NT01s on 18x12 ET41 without any issues. I have also run them on 18x12 ET44 without any problems. Rear fenders are rolled. My friend now has my old ET44 wheels with 315/30/18 PS2s and has zero issues even though his fenders are not rolled.
