GT2 Front Top Air Vent/Grill On Stock 996 Bumper
I love the look of the GT2 bumper on our cars, particularly the middle vent below the crest. However I'm unwilling to do the complete redue of ducting and bumper replacement to convert the front of a stock 996 turbo to a GT2 look, especially with all the functional ducting that would be needed.
That being said, I was wondering if its possible to somehow mod the stock 996 turbo bumper to accept the GT2 top/middle air grill (the one below the crest) without replacing the entire bumper. Is it possible to cut and add or no? Has anyone done this? Links?
Any help or ideas would be greatly appreciated. Thanks.
http://i145.photobucket.com/albums/r...anceCheck2.jpg
As I stated, I'm not/not looking into replacing the entire front bumper. My question was if there is a mod to the STOCK bumper that can be performed such as cutting and installing the diffuser . I'm just doing it for the cosmetics, I could care less about the functionality.
Wondering if anyone has performed this or if there is a kit available to do this.
Furthermore, it appears that the ducting and airflow to the radiators thru the main vents is different then a reg turbo, several threads on this, which is another reason I don't just want to put on a different bumper cover.
Anyhow, I supposed one could install the upper frame (996 575 326 30) if they were super handy with fiberglass. You'd have to cut out the bumper for the frame and glass in tabs and/or a lip to bolt the frame to. My concern would be getting a perfect jig set up so when you did the glass work the bumper cover is sitting it its exact shape and not distorted. Being as these bumper covers are pretty flexible this could be a challenge. What I've done when glassing these type of bumpers is to use a slow setting epoxy so you have about twenty minutes or so. I do the glassing and then install the bumper before the epoxy sets so the bumper is in its proper shape.
If you're willing to risk ruining an expensive bumper and you are good with glassing and filling then I'd say its doable.
Some call it a splitter (though I believe this is also what folks call the component attached beneath the bumper or a lip), some diffuser...what ever. The "slats" do indeed allow air to come from underneath, but I believe it is Bernoulli's principle that creates the down force...The air on top of the car, just above the boundary layer, is travelling fast and creating a down force reducing low pressure zone on top of the car. A diffuser is a piece that attempts to slow, or spoil, the fast air on top of the car, in-turn reducing the low pressure zone and provides downforce instead.
And the stock bumper is polyurethane...
see here
The OP wants to attempt modding his stock polyurethane bumper so using epoxy would be a good bonding and molding material. I don't think I'd ever do this as the time and expense involved wouldn't be worth it IMO. Plus I just think it wouldn't look proper and be a mismatch with the rest of the bumper design.
OP, here's a pic of the back side of a GT2 bumper so you can see how the frame fits. Hope this helps.
The center duct on the GT2 bumper setup changes where the air that goes through the center radiator is routed. I know this as my car has a functional GT2 front cover on it, and changed the parts out to complete the ducting myself.
The inner fender wells are different, the bracing for the radiators is different, and the ducting behind the center radiator ducts up vs down.
