cd changer not recognized
I just got an 04 TT with a stock navi setup. when I select the cd changer I get the error message "no cd changer". I have inserted a couple cds, checked connections and still same message. The cd changer was dealer installed after initial delivery. Obviously the battery has been replaced a few times. Is there any trick to having the head unit link to the changer? I did something before on my old unit in my '02 when I set up the aux input. any ideas?
As long as i am at it, is there a plug to connect my iphone as an mp3 player?
I really do not want to upgrade anything, I just want what I have to work.
Photos are coming when i can figure out how to upload to rennlist from my ipad.
This has resurrected a non-functioning CD player for me several times.
Another possibility though one which I can not recall affecting the CD changer is sometimes when I turn on the key and after starting the engine the radio comes on but doesn't work. Everything about the radio looks ok but there is no sound.
The "fix" is to turn off the key and leave it off for some time.
I've never experimented with how long is necessary I just shut off the engine when I get where I'm going and when I come back to the car some minutes later the radio works just fine.
Based on my observation a possible minimum amount of time would be 3 minutes but it could be longer.
Or you can shorten this by unplugging and then plugging back in the fuse (or two) that protects the radio circuit. I have not bothered to learn where this fuse is, or fuses are, I just do without the radio for a while.
Note the only times I've had the above issues with the radio has been before the battery gave up the ghost. The battery didn't die right away but it was on its way out.
On a somewhat related note, when RAC connected my 04 TT to their Piwis to see why my keys weren't connecting to the seat settings, my PCM somehow lost the navigation. Nothing they could do would get it to recognize that I had navi - even after reprogramming. We unplugged the entire PCM unit, and a few minutes later when we reconnected it all everything worked fine. No explanation how or why, but maybe this will cause your system to "recognize" your CD player too.
I'd pay a premium if Porsche would outsource all electronics to Lexus or Infiniti. Germans know driving dynamics, but they can't hold a candle to Japan for electronics.
my experience lately with the cdr23 and inadvertent and unasked for on/off ( not recognizing inserted cd's etc ) is that the cause of the problem *may* in fact, be a faulty ignition switch. yes, that's what i am told. i will try and report back as soon as the new $6.00 996/986/vw part goes in. it turns the radio on/off while driving, and it freaks me out, to say nothing of annoying. odd, but true. the fix was recommended to me by my tech that says the issue is not unknown to him, and that the replacing of the ignition switch, ( in spite of no other symptomatic behaviour from the switch,.. or key operability ) will cure this anomaly. stranger things can happen, so we shall see.
my $50 iphone/ipod connectivity issue has been cheaply ( if not crudely ) *solved* by buying a motorola t505 which connects the iphone thru the ( at times phantom ) cdr23 and plays mp3's as well as allows me to make/take calls.. which while drving this car is unusual for me anyway. it ain't pretty ( the t505 ) but it works and just clips onto the pass side visor. works pretty well, actually. just circa 2003 technology. actually, i think it suits the car lol
