996 Turbo Forum 1999-2005
BBI 996tt crossflow "X" 3" catless exhaust.
Old 01-31-2013, 03:54 AM
bimmer81
bimmer81's Avatar
Default BBI 996tt crossflow "X" 3" catless exhaust.
Up for sale is my BBI 996tt catless exhaust. I've been through 2 other exhaust and this is by far the best I have owned. This exhaust is top notch in every way, no drone, ceramic coated dual tips, optimum power gains, and sounds bad *** Note: this system has v band flanges, I can help the buyer source regular flanges. $3200 shipped.
Old 02-05-2013, 11:35 PM
bimmer81
bimmer81's Avatar
open to offers
Old 03-27-2013, 03:34 AM
bimmer81
bimmer81's Avatar
bump
Old 05-21-2013, 12:08 AM
bimmer81
bimmer81's Avatar
This needs to go guys, major price drop. Priced to sell at $2475!! This sell for over 4k!
Uploaded with ImageShack.us
Old 05-27-2013, 11:10 PM
coil222
coil222's Avatar
really interested, have the cash now. im new to 996TT. can you run catless w/ boost creep, CELs etc?
Old 05-28-2013, 01:47 PM
bimmer81
bimmer81's Avatar
If you run catless on a non tuned/flashed tt you will get cel. Usually if you go catless your tuner can fix that easily. My car was tuned by Protomotive. If you have not flashed/tune your car I highlt recommend Proto. Todd custom tailores your file to what you want and the hardware that you are running.Who ever you choose to go with can easily take care of the cel. My car was a 1000whp fully built car. No issues with boost creep.
Old 05-28-2013, 07:59 PM
coil222
coil222's Avatar
I figured you were making big power with those ext. wastegate dump tubes.
Are the cat bypass pipes welded to the exhaust?
Old 05-28-2013, 08:45 PM
bimmer81
bimmer81's Avatar
No not welded. The exhaust is a modular design and slip into the exhaust.
Uploaded with
Old 05-29-2013, 09:12 PM
coil222
coil222's Avatar
so i could order BBI cats and run it on an otherwise stock car then?
Old 05-31-2013, 01:18 AM
bimmer81
bimmer81's Avatar
Yes you can, but they are pricey. Each German cat is about $1000 plust the cost to build the pipes. I actaully have the cat pipes as well and wanted to keep them for a future project. I will sell them if thats what you want but it wont be cheap. Lmk. Thanks
Old 05-31-2013, 02:10 PM
coil222
coil222's Avatar
Yeah. I just got the car so I'm stock. I'll probably eventually end up w/ most of the bolt ons replaced, maybe one of the EVOMS 600 HP setups or something, but for now I'm not looking @ doing a Chip/Tune etc so catted would probably be best. Sure go ahead and shoot me a quote for the exhaust and the cats if you're down to part with them.
Old 05-31-2013, 04:35 PM
bimmer81
bimmer81's Avatar
Here are the cats, check your pm
Old 06-02-2013, 03:41 AM
coil222
coil222's Avatar
these will bolt to stock turbos without issue right?
Old 06-03-2013, 07:27 PM
coil222
coil222's Avatar
and are the cats 100 or 200 cel?
Old 06-04-2013, 01:40 AM
bimmer81
bimmer81's Avatar
These are 200 cell cats. The flanges I have are v band so you will need to replace those with 4 bolt flanges which are inexpensive and any exhaust shop can do for you, No biggie.
Quick Reply: BBI 996tt crossflow "X" 3" catless exhaust.
