More Maintenance and A Mod
Having encountered some issues over the past few months, I had the car in for some service work:
1. Replaced oil pressure sending unit with Porsche part.
2. Replaced diverter valves with Bosch 710N.
3. Replaced tappet solenoid brackets on both banks.
Also had an X73 suspension installed.
I purchased the system used from a Rennlister. I shipped the rear shocks to Bilstein for rebuild, and purchased new X73 specific shock mounts (996-343-980-15/16), and new bump stops before install. Haven't put a lot of miles on it, but I like it a lot even without an alignment.
Hopefully 2013 will bring more miles and less maintenance.
I'm a bit taken aback by reading that while you changed the suspension you have not yet aligned the car. if this is right I would make the comment the suspension change over is only half done.
While the alignment could be ok, spot on in fact -- if one still believes in miracles -- the odds are it is not ok. While the car may not feel out of alignment I suspect the tires are taking a real beating.
Agree on the alignment - its not a daily driver - I've only driven it about 25 miles since I got it back (2 days ago). And absent other suggestion, I'm going to have dealer align (quoted $380 - high ?).
Don't wait too long on the alignment. I ate a set of rear tires in about 75 miles after installing my x73. Most of that was driving to the alignment shop.
Mine drove great as well before the alignment.
At a dealer the other day I had new front tires installed on my Turbo and had the car aligned and the cost of the alignment was $349.
I've gotten some breaks in the past on alignments, sometimes getting one for less than half that cost say after buying a set of new tires, but not this time. I did get a discount on the new tires. They listed at $328/each but I was charged $262.40/each.
$380 for an alignment is high but unfortunately par for the course based on my very recent experience.
I'd find an alignment shop that you local Porsche Club recommends. I paid 360 for full alignment and corner weighting, so that sounds high to me.
I got mine done for $180 at an Indy shop. No corner weighting possible on the X73. I have 6000 miles since and the rear insides are only showing about 1/2 wear. I think I'll get 12 to 14 out of them. The fronts look almost new.
Forgot to mention that I also had a new Interstate battery installed after 3 years.
Car is at dealer now getting aligned to X73 specs.
Pics - shocks almost look brand new:
