Wheel spacers
Any issue putting 14mm spacers on all 4 corners of a 996TT with the X73? Standard 18" wheels and tires.
I measured according to Adaptec's instructions and there seems to be good clearance. Just thought I'd ask the brain trust.
i ran spacers on stock twists after lowering the car for the looks as well as the stance. i think it's an excellent decision, and that you'll be pleased with the look and more importantly even, the handling.
i ran 7 front 15 rear. was perfectly flush no rubbing, looked awesome. my new wheels achieved the same thing without spacers though.which is better still.
go for it.
go for it.
SSST ~ Either 7mm or 15mm or combo thereof as others do will definitely look better than none at all IMHO. I'm running 7mm all four corners. I have the same wheel offsets, tire sizes and X73 suspension that you have. To help with your decision, I took some pics so you could see what the 7mm looks like:
![Name: st1.jpg
Size: 396.3 KB](https://rennlist.com/forums/attachments/996-turbo-forum/648621d1342365491-wheel-spacers-st1.jpg)
![Name: st2.jpg
Size: 446.6 KB](https://rennlist.com/forums/attachments/996-turbo-forum/648622d1342365491-wheel-spacers-st2.jpg)
![Name: st3.jpg
Size: 362.2 KB](https://rennlist.com/forums/attachments/996-turbo-forum/648623d1342365491-wheel-spacers-st3.jpg)
![Name: st4.jpg
Size: 437.1 KB](https://rennlist.com/forums/attachments/996-turbo-forum/648624d1342365491-wheel-spacers-st4.jpg)
![Name: st1.jpg
![Name: st2.jpg
![Name: st3.jpg
![Name: st4.jpg
![Name: st5.jpg
Size: 411.0 KB](https://rennlist.com/forums/attachments/996-turbo-forum/648625d1342365491-wheel-spacers-st5.jpg)
I installed the 17mm factory spacers on the front and have no issues with rubbing so anything less and you should be fine. Nothing in the rear yet but thinking 7 or 10mm to even out the spacing.
Basic Sponsor
Just make sure that you use a quality set of wheel spacers that are Hub Centric and that you also use bolts that are longer to accommodate your new spacers. If you need any help getting anything, I would be happy to assist you with anything that you need.
I have the Adaptec spacers - 14mm rear/7mm front - sorry no pics.
(Now I just need to get a new suspension - to make things look and feel good).
