another spare tire question
Just took a spare wheel/tire combo to the local dealer to get a new tire put on it.
The service guy calls back and says you can't get a tire put on the wheel but that they will sell me, for $650, a new wheel/tire combo.
Is this really the only way a dealership can get your spare back into commission? Is it possible to mount one of those collapsable spares to an existing wheel? I've seen a number of old ads offering tires. Would those be bad deals?
Anyone have any experience or wisdom they can pass on?
I can't say I would trust a re-mount of a collapsible spare.
It's hard enough finding someone capable of not buggering up your wheels on a regular tire change.
As far as used goes, you will have to wrestle with the fact that some will be 6+ years old. For the most part, that is the industry standard 'expiration date' for tires.
Will an old spare be safe, even if unused? Even though you hope that spare spent most of it's life in the frunk, it still could suffer some degeneration.
Check the manufacture date before any used purchase and look carefully for any signs of dry rot.
BD
BD
Burgled
Why would you worry about a spare being over 6 years old? Its just to get you to a place to fix the original tire not do a DE. If it doesnt hold air call AAA.
The old one was inflated and now will not reset to the collapsed mode. I thought that PCA clubs wanted the spare in the frunk as it is part of the protection in a collision. I figured I'd have to get a new tire to be able to do this and that is how I arrived in this situation.
I don't know that I'd be relying on the spare as I will trailer to the track but if I'm gonna get a spare I guess I'd like one that is capable of doing the job!
Got home, took off spare, drained air, and the tired easily collapsed. Strange yours in not cooperating. Maybe wrap a belt around it, and force the remaining air out?
Did a full Concours detail on the spare, and put back in frunk.
Did you call Sunset to see if they will just sell the tire?
If that's the case then explain how the GT2 / GT3 which has the identical body structure can be sold by Porsche without a spare. There is just a foam insert in the trunk of the GT2/3 which holds the compressor, tire sealant and a few other minor things. I put the GT2 foam insert in my car deleting the 40lb spare....
Checked with Suncoast. Cost was less then local dealer, but they can only sell it as a complete unit. You can't just buy the tire from them.
I wonder, IF you could get the tire, whether a regular tire store could mount a collapsed spare....... do you inflate it, break the bead, remove old, install new inflated spare then deflate/collapse and store or can you mount it collapsed?
You can move a lot more "Luggage" without a spare.
Not sure why folks remove the spare for weight reduction. My front end is already too light. Removing weight from the rear sure, but from the front...no way (unless you enjoy no steering...LOL)
You have about 1400lb being supported by the front tires. You'd have to be super in tune with your car to notice a difference of 40 lbs up front. I track my car often and and for me changing tire pressures has a much greater effect on steering response than 40 lbs ever will. Trailbraking will easily rotate these cars despite the light front end. You can also easily compensate for a lighter front end by a combination of stiffer rear sway and/or more neg. camber in the front. I run -2.3 camber in the front and the front end bite is fantastic. I took out the spare because I know I'd never use it since I have no room in my car for a wheel if i were to remove it off the car. None of the Porsches after the 996 have a spare if I'm not mistaken.
Actually I noticed instantly when I tried to drive the car without the spare. Those 40 lbs. may not seem like much, but are located low in the car's COG. Regardless, the average driver...me (that isn't interested in shredding the inside tread with your camber settings) already notices the lighter front end.
