What do you think?
2002 996TT with about 16,500 miles... no accidents, looks nice but 5 owners (according to car fax)? Should I walk away and not even spend money for a PPI? and why or why not?
It causes pause. I would be very, very skeptical, and walk. Unless of course you have time for curiousity sake. I would investigate the owner trail, starting with the last one. But only out of curiousity.
I would be a bit concerned, however keep in mind that in some states the dealers are referenced as an owner in the carfax, so maybe this car in reality only had 2-3 "real" owners, check the ownership length/mileage for each owner, this should be a good indicator
Yes, check out the owner trail. Carfax is not always very accurate. I bought my car from the original owner yet the Carfax showed two owners. He moved to a different state and when he registered it there that showed up as a new owner. Also, "no accidents" isn't always accurate on Carfax as well. Due diligence with a thorough PPI should be followed.
My thoughts as well. Good luck
Agreed, in addition to car fax, purchase car proof, which i believe searches more data bases than car fax.
