Eureka!!?? Fuel Vent line broken
I do NOT know for sure, but John from Protosport thinks what I stumbled on last night is likely the pesky vac leak that was throwing p1126/1128/1133 codes. I wanted to inspect my fuel line as the car is 11 years old, more just preventative. I removed the cover and discovered this hack job, which might be hard to see-the epoxy was loose, stained from fuel(i guess I found the fuel smell) and the line was seperated from the sender as the epoxy was shot....freakin hack job....
