Moaning sound
hey all,
I just got my 02 turbo. I'm thrilled with it. I do have a question though. I noticed a moaning sound from the car. It can be heard at idle, and gets worse when you turn the wheel. My first thought is low power steering fluid. What do you guys think? Is there something else that commonly makes a similar sound?
Some 996tt have an issue with the PS control valve,, which requires the resevoir to be replaced. No cheap fix. The part costs around $800. Could also be an idler pulley.
your instinct is probably correct. check the pentosin reservoir for the proper level. if low it will "whine" when turning the wheel. the sometimes faulty ps reservoir valve is more like a whistle that goes away upon engaging the clutch. oh, the familiar sounds of the illustrious 996TT.
