Glove compartment light
I went to lock the car and got a single horn blip. I’ve checked the usual lids, to no avail. It took me some time to work out that the glove compartment light is not switching off. I’ve taken the light bulb out, so I don’t wake up to empty battery in the morning. Then I found this contact of some kind in the glove box. I have checked pet but cannot see where this could be from or where micro switch is located. Anyone had this?
the metal arm that you show connects to a switch which in turn mounts on the left side of the glove box plastic frame. when the glove door closes it makes contact with the metal arm and closes the switch which turns off the light. if it keeps popping off you might need to glue it to the switch.
Thanks mate. Where? Can you tell me some more please? Where to the side? Can you point me in the right direction on the actual illustration I attached? Do I need to remove the glove box to re-attach?
If you had the good sense to get a 2001, you wouldn't have to deal with this crap. It doesn't have a glove box!
I'm kidding, of course. Just a little frustrated that I don't have a glove box
You are damn right! Such fiddly design! What’s wrong with a proper small physical switch like on the fridge; push-in push-out, rather than this micro switch crap? In my 944 turbo switch never broke. They can stuff 997, 991 they are just getting bigger on marketing and smaller on quality.
its best to remove the glove box. the switch i'm referring to attaches to the frame body of the glove box on the left side towards the rear. there is a slot on the frame where the switch attaches to and the metal arm protudes thru the slot. as you close the glove box the side of the box makes contact with the metal arm and pushes the arm in which in turn closes the switch.
simon:
Thanks. I agree to a point, but surely putting the micro switch on the top ledge facing downwards or the back facing frontwards, so that the glove box would push into it when closed would have been a neater solution without the need for this flimsy metal part prone to disengaging the micro switch base and falling out?
