Worn Bushings & Mounts
Fella's
i generated this thread on 6speed based on my findings of a replaced tranny mount
http://www.6speedonline.com/forums/9...ifference.html
i was wondering what other mounts i could replace and or bushings
here is a short list i came up with
motor mounts - plan to get 997gt3rs ones
control arm bushings
top mounts, but i will hold on this one in case i do coilovers and soilds are installed
any other easy ones i can do? please provide a part no if possible.
where the hell are the chassis mounts? anyone got some part numbers?
some past experiences would be appreciated
mike
mike
GT3 player par excellence
drive your car to sharkwerks.
whatever alex puts on it good.
whatever he doesn't put on is not needed.
no need to know part numbers and killing yourself doing all the research.
find a trustworthy shop.
I've had the motor mounts replaced on my C4S with Wevo SS mounts and absolutely love them.
http://www.wevo.com/Products/ChassisProducts/WevoChassisProducts-997SSEngineMounts.htm
Mine were replaced for shifting reasons though. Depends on your goal. If you want to go stiffer but not solid I reco Wevo from experience. I have also had solid (long story).
I spoke with the guys at Wevo several times before buying and they are quite knowledgable. Made me feel comfortable with the purchase.
Feel free to PM if you need more info.
Good luck.
Good luck.
then a lot of research are needed.
depends on what u plan to do. solid, semi solid, monoball ***** are not all that good for street use. if you must have them, there are a lot of mounts you can replace.
engine mount
tranny mount
goto monoball bearing upper control arms.
lower control arm, thrust arm puck on the lower arm, thrust arm (aka tension arm) can be monoballed. front tie rod. all four upper shock mounts. you can get to tarett's web site and find all the parts you need. RSS, PMNA, ERP, GMG, TRG and many others all make similar parts.
it would be best to have a ride in a solid/semi solid jointed car for an hour or so. that may change one's perspective.
engine mount
tranny mount
