headlight level sensor?
inside driver side wheel well, bolted to frame, is this common? plastic rod is broken, but can't see where it connected to... and i am not sure this is what it is, but think so from working on audis, thanks ahead, kevin
Page 104 should have what you need (for the fronts). Sounds like what you describe.
http://www.porsche.com/all/media/pdf...6T_KATALOG.pdf
