Any info on this 03 996TT
I am considering buying this car and wondered if anyone has any info or opinion on this car and its price. I never had a Turbo so know little about them..I am considering selling my '00 Cup car and recently completed 99 Spec Boxster.. so as you can see all together different rides.. any opinion is greatly appreciated.
here are the links
ebay http://cgi.ebay.com/ebaymotors/ws/eB...ht_7821wt_1002
dealer site
http://www.craveluxuryauto.com/web/2...0Carrera-Turbo
here are the links
dealer site
Very nice looker
Looks like a great street/track combo with some nice goodies. I've never been a big fan of the Techart kits. But then again, I really prefer the OEM aero units
Can't comment on the price other than it's over $50K. Probably reasonable given the PCCBs, which are a plus or minus depending on their condition.
I'd get a PPI through a Porsche dealership. Porsche mechanics are **** about the most minute detail. They'll probably gag over the non-Porsche parts but for the engine core and transmission and the brakes they'll be worth the money spent(especially if there's a chip on a PCCB rotor that other mechanics wouldn't care about).
Do a CarFax check.
Do a CarFax check.
I looked at the car on ebay too and pulled up the factory options on the car. It was originally very low optioned. All the stuff you see has been added. My question is why would someone add so much costly stuff and then sell it for a loss? Had the car been damaged before the mods? Was it raced or tracked? Often times a seller will come out better returning a car close to stock and separately selling high end race parts. Lots of questions on this car.
here are the links
dealer site
here are the links
dealer site
Not what I look for in a used car I want to own.
I'd give it a miss.
Sincerely,
Macster.
thanks everyone... my use will be strickly track ... love the thought of the HP / torque but do not want to buy time bomb.. just got off the phone with the servicing dealer.. says that car was moded by Evolutionm in AZ-- http://www.evoms.com -- in late 05 early 06 ran it for that year then bought a Cup car and only used the Turbo occasionally after that... PCCB imo are negative ...other than motons does not appear any other suspension work done...got to do some more checking before I do a PPI etc
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
I'll be easy on you though and not charge you too much to take those bad old PCCBs off your hands.
Sincerely,
Macster.
To the OP - if its going to be primarily a track car - it looks like its already got some nice goodies. I wouldn't pay a premium for the mods, but if you're going to track it, and its passes a PPI, might be a go.
I'm with Dell though, don't like the bodykit at all.
A few pounds in weight savings on a street car? Seems a little overkill, these brakes in order to provide the stopping power they are capable of, need to be heated up as in all composite type brake systems. If run too cool the braking distance compared to the non PCCB could not be as good. So it's more than weight savings. I don't think on the street the weight savings of the PCCB's is a recognizable issue as it relates to a daily driver. Of all my Carrera's the stock brakes have always lasted a long time. That is based on the weight of the car vs: the size of the braking surface of which Porsche is known for.
As far as those who track their cars remove them, I can understand that, because most are not on a racing budget, but as it relates to a race team they use them and can bear the expense since the braking power is more aggressive.
Reduced dust.
And much reduced weight right where it does the most good.
Everybody agrees on the advantages of a LWFW.
Well, replacing 4 heavy steel (cast iron) disc brakes with much lighter PCCBs is like 4 times as good as going to a LWFW.
With the PCCBs installed there is less weight to accelerate, less weight to slow down, less unsprung weight. The car accelerates better, slows/stops better, and holds the road better.
Just what one wants in a sports car.
Sincerely,
Macster.
"The single greatest benefit of CCBs, however, is their resistance to brake fade. With repeated use — especially at high speeds — brake temperatures can rise dramatically, causing performance to drop off. This is a common occurrence during racing, but can also occur if you ride your brakes down a long mountain grade rather than downshifting to take advantage of engine braking. In either case, the consequences can be disastrous. Unlike conventional brakes, CCBs are designed for outstanding performance at very high temperatures. Unless you're spending your weekends at the track, however, you probably won't be pushing your über brakes hard enough to find out just how great they are. And if you do manage to find out on the street, no need to brag to all your friends — they'll know all about it from the evening news."
As per the above tech article there is a compromise, and ceramic technology works better when hot. Be interesting to see 0 to 100 comparison on normal temp standard brakes vs: the PCCB's. There is another variable that hampers the true effect of PCCBs, it's street tires! As far as acceleration let me know how much faster your car gets! My opinion from a performance standpoint and not being able to drive at Autobahn speeds, I can buy a lot of rotors and convert over to sport pads and 6 disc calipers for a heck of a lot less. Get get near the performance when the PCCB's get hot from a braking perspective.
Not trying to be difficult, but it seems to me there are other options that come very close when it comes to US highway speeds and daily driving as oppsed to a set of 15K brakes.
