996 Turbo Forum 1999-2005
Front Strut Removal
Old 12-29-2010 | 10:23 PM
2300cc's Avatar
2300cc
Default Front Strut Removal
Hello,
I did use the search feature and found conflicting answers. I am in the proces sof removing the front struts out of my 2003 996 c4 and so far i have the steering rack, and caliper disconncected and I am purchasning a ball joint popper tomorrow to pop off the control arm.
Now is it possible to remove the front strut without removing the half shaft? I have found posts with people saying you have to do it and other saying you do not. I am hoping I do not but any help is appreciated. Thank you!
Old 12-29-2010 | 11:28 PM
raineycd's Avatar
raineycd
From my experience you have to remove the shaft. Either from the outside on the hub or it will just slide out from the diff. I had one side that came out easily from the hub and the other didn't so I had it come out on the diff side.
I did it without removing the control arm, but you will need a spring compressor to get the stock strut short enough to rotate out.
Quick Reply: Front Strut Removal
