ECU/Chipping
I have an X50 with the UMW tune, Europipe exhaust, and the diverters. No clutch slip whatsoever. The whole package makes one wonder what Porsche was thinking. Amazing value from Kevin. AS
ECUdooberhead, why would you mail your ECU to Kevin? When I got his tune It didn't even require me to remove my ECU. Just plugged in a little programmer and 30 seconds later it was done.
Location: Chicago - UMW Flash, UMW Performance Clutch (dual-mass), RUF exhaust, Evoms Bilit DV's,PSS10's, Pioneer Nav
I remember having to supply Kevin with the stock map before he could create a custom performance map. After he was done with the file, I downloaded and installed it. I bought the Pocket Power device to switch from stock to performance at will.
Maybe that is what ECU was talking about. I certainly never removed my and sent in my ECU.
My ECU wouldn't accept the slave cable. Kevin seems to think it had been flashed by a PO and reflashed back to stock, which locked out the ECU, so I had send the entire ECU to Kevin to be worked on.
