996tt RWD conversion?
Yup, Should have mentioned this in my last post... I've got a built gearbox and a Guards LSD. Wouldn't think an open diff and RWD conversion would make for a happy balance to these cars...
Mike
Mike
Back to life with this, as prices for 996 Turbos are way down and they share the 996 GT3 engine type (true dry sump) with a lot more power this is an interesting choice for a "drive it to the track" car.. Do the 996TT all not come with LSD due to the AWD? No big deal to add one if I remove the FWD stuff I assume?
yes, they don't... and perhaps even more timely if you're considering it? read mkellys response just before yours. this is exactly what you wan't to avoid. namely running rwd "open" diff. it is utterly pointless and even "less" a car than awd is/was.
you MUST include an lsd in this conversion.
i think the best of all worlds could be summed up with jeff zwartz and his bbi built turbo powered cup car for pikes peak. now that is a seriously purpose driven car lol
the "open diff" situation only becomes an issue if you convert to rwd from awd. if you convert to rwd without installing an lsd you will often find yourself spinning one of the two wheels.
On a track it is essential but on the street not so much.
I love the RWD with GT2 specs
but anywhere and anytime you could/would spin wheels, a properly outfitted tt that is rwd and has an lsd, will help to eliminate any excessive wheelspin situations. i drove my current car open diff with simply the cardan removed to evaluate for myself what exactly power exclusively to the rear wheel(s?) lol would be like, prior to the addition of the wavetrac i use now, and it's night and day. one must run either awd ( as the car came ) or rwd with an lsd fitted. there is no workable compromise as there is simply too much power to the rear wheel(s) otherwise for the power to be properly applied in an rwd configuration.
in my limited experience with both.
I agree, LSD required for 2WD, especially since I would never leave well enough alone and look for some tuning mods to up the HP and brakes. The prices are just too attractive not to give this serious thought. What's a new Guard LSD installed? Set of big (steel, not Ceramic) brakes? Bolt in roll bar? I'm sure there is also a lot of extra weight that can be removed while keeping her streetable.
May even keep it AWD and make it my DD, who knows!
...it never freakin ends, does it... just when i get on top of any/all mechanicals to distract me for a few weeks/months allowing me to focus on something purely cosmetic, i'll get a grand idea like "hey! i could use a new windscreen" or some such thing. i just never ends......
