HELP MaxJax mounting questions
Cross post from off topic and 996 forums
My MaxJax lift was delivered yesterday. I plan to use it for maintenance on our other cars.
I hope to tap the Rennlist collective knowledge base.
How far apart did you mount the posts? Are you happy with the distance?
Please specify if you are giving dims from inside or outside edge of the plates.
Do/have you used the lift on other cars/SUVs?
Thank you,
frank
Thank you,
frank
Super Moderator
Needs More Cowbell
Needs More Cowbell
Have you seen any of these threads?
https://rennlist.com/forums/964-foru...ghlight=maxjax
(this is from Jaime...aka Wachuko)
https://rennlist.com/forums/996-foru...ghlight=maxjax
https://rennlist.com/forums/924-931-...ghlight=maxjax
Lewis,
Thank you
I did find Doug996inkc and Choinga threads but not Jaime. I have PM'd a couple of the posters in those threads to see how satisified they were with the spacing.
Found in Jaime's Pelican thread. He has the best of both.
"When I am done I can put everything back in the garage... the mid-rise I had was advertise as portable... no way in hell... this one on the other hand, is a breeze to move around. So I have it setup so I can use it in the single bay (115" between outside border of the towers) or the double bay (128" between outside border of the towers)."
Thank you
