The LVDell "I'm not going to mod my car" mod thread
#31
Dell, You're soooo doomed... The first time you track that car, you're going to kick yourself for spending the money on that X73 setup...
Before you other guys start howling at me, let's not forget that Dell was running 2.03s on VIR full in his GT3. What is going to happen is He's gonna expect the 996TT to do things it can't currently with that setup, and that's gonna be it... I predict a full suspension and brake upgrade by mid summer...
Dell, don't say a word man... Just read the title to your thread!!! HAHAHAHAHAHAHAHA
Mike
Mike
#33
The non-smokers rear center console insert that replaces the ashtray is also very easy and runs about $50. You remove the ashtray and that exposes 2 plastic torx screws that need to be removed. Then you just remove the old piece away from the rear center console a few inches so you can remove the window switches and the connector for the light. Replace the window switches and install back in the space with the 2 plastic torx screws and their little plastic receivers. You just leave the light connection inside the rear console as it is not used.
These are literally 5 minutes total to complete.
Ordered them almost 2 months before the car arrived and to make it even worse, I had them before I had a car picked out!
#36
You ain't kidding Matt, which is why I will NEVER be delusional enough to think I can take it on track and do what the GT3 could do.
#42
GT3 player par excellence
dell, what can i tell you. you are pathetic bro.
no mod hahahahaa, LMAO.
#45
BD...I'm not turning my car into a track rat. Motons would only make sense if I put the car on a serious diet, replaced all the rubber in the suspension, and ran slicks. If not, that's a waste.
