You obviously got a steal on the carillo's.. Make sure they have the good bolts.. Im not sure how many models they make for your motor but most times they make 3 different models.. Just be sure you have what is best from them.. good luck!!!
Mike
Yeah a steal to say the least. They do have the better CARR style bolts vs their WMC standard bolt offered which I was pleased to see. If it wasn't for this deal I certainly would have gone with the R&R's. They are solid rods for sure!
Right now I'm just waiting for some info on the slugs that are going to be made. Have to give LN a call sometime this week If I get a bit of time to do so.
What I do need to find/locate is a stock sleeve. #3 was damaged beyond repair when the pin gouged the bore wall, and if I remember correctly you can only buy the sleeves from Porsche as a piston/ring/sleeve assembly for ~$1100 each
