CDR-220 upgrade
I am getting ready to ditch the CDR-220 in my 01 996t. Can I just pull it out and wire in any other unit and does anyone know where I can get necessary cable adapters etc to tap into the factory connector (power / speakers etc).
Also, I am unsure if the car has a separate amp. The replacement unit may have a built in amp so was wondering if anyone knows if the stock CDR-220 with in the 01's had internal amps with speaker wires coming to it or an external amp.
Thanks.
Thanks.
Yes, you can it is not fiber based. The amp was a an upgrade, so in your trunk you would see the amp, if it is not there, then the 220 is powering your system. Almost any radio will be better than the 220. I think there is a cheap able adapter available directly from Becker. Also, there is a Blaupunkt adapter that works too.
Thanks. I am planning on buying this kit and relocating the AC controls, and installing a 2DIN sized unit with nav.
http://www.euromotorspeed.com/servle...che-996/Detail
Looking at the pictures of the kit, it appears it may have to adapters to tap into the factory plugs. I will have to email them and ask, but if anyone here knows that would be cool.
Yes, that's a good kit. You may still have to modify it a little. The folks that make the kit have some good instructions (although they are for a boxster). The harness may not match up 100% but it's close.
Do a search on the 996 board. Recent thread by RallyJon (I can't seem to link it).
