Any docs on ECU removal from 996 TT CAB?
Can you guys point me to the procedure for removing the ECM/ECU from a 2004 99 TT CAB. I know it's behind the backseats on the driver side. I know you have to remove the carpet. I don't know the rest....
Thanks,
Michael.
Thanks,
Michael.
First they can tell by looking at the physical ECU if the fasteners have been turned. Second, with PIWIS they can tell if the ECU has been flashed. There are several options to flash the ECU without removing it...through the OBD port....but I believe that if the Porsche tech. is savvy enough, he can tell if the ECU has been modified. (yes the mod is logged)
