We are happy to announce Performance Friction will be producing two piece full floating disc assemblies to replace the stock 996 TT discs. The engineering department at Performance Friction is working on the final pricing and expected delivery time. Once set, we will be accepting pre-orders.
Great news. I read in another thread that the rear hats are zinc nickel plated cast iron. I assume this is to allow usage of the rear hand brake. What are the front hats made of, and more importantly how much difference in mass compared to OEM front and rear? Thanks!
You are correct regarding the rears, front hats will be aluminum. Won't know weights (Rotational mass) until it gets through Engineering.
I upgraded to 996GT3 6 piston front, and rear calipers, 350mm 997TT discs at all corners, and it was a direct bolt up. Got the kit from Kevin at UMW. I keep cracking the front rotors though.
If the rotors you have are a direct bolt on for a 996 GT3, 350mm, we have them.
That's a shame. I guess this is why none of the AMLS or Rolex series cars use Porsche rotors.
