996 Turbo Forum 1999-2005
Another ABS PSM problem but also getting Generator failure
Old 02-01-2009 | 02:08 AM
4G64T's Avatar
4G64T
Cruisin'
Default Another ABS PSM problem but also getting Generator failure
I am getting the same problems with ABS and PSM light on but also get Generator failure. The voltage reading goes to max - 16 volts and the air con goes off but the headlights work fine. Yesterday was the second time it happened. I pulled off the road and turned it off and on again for abot 5 secs but the problem was still there. I took the car home and turned it off and then on again after 10 secs. The problem disappeared. No body seems to mention generator failure. Could this be a problem with the alternator?
Old 02-01-2009 | 12:22 PM
wross996tt's Avatar
wross996tt
Get the codes read
Old 02-01-2009 | 01:48 PM
4G64T's Avatar
4G64T
Cruisin'
I wish it was that simple. I live in the Philippines and very difficult to get a code reader. Any one you recommend so I can get one next time I am in the US?
Old 02-01-2009 | 02:20 PM
wross996tt's Avatar
wross996tt
Get a durametric....they give you the cable and the software just loads on your laptop. It will save you in the long run especially given you don't have access to many dealers.
I believe they will ship it to your house.
Old 02-01-2009 | 11:16 PM
4G64T's Avatar
4G64T
Cruisin'
I just remember that I bought the cable when I go the Softronic reflash - I have since changed my reflash as I got the car tuned an flashed on a dyno in the Philippines. Can I get the codes after the car has been turned off and there are no lights showing any more or do I have to check when I have the ABS, PSM, Generator lights on? Thanks.
Old 02-02-2009 | 01:55 AM
wross996tt's Avatar
wross996tt
The codes will be stored in the DME until cleared. Durametric, PIWIS or PST2 will fid them and clear them.
Old 02-02-2009 | 09:35 AM
4G64T's Avatar
4G64T
Cruisin'
Wross, this is what I am seeing:
9130 Power Supply Cleared
9114 PCM Control Unit Cleared
9101 Can Drive bus Cleared
9133 61 Low with engine running Cleared
9150 Spoiler Control Cleared
P0563 Porsche Fault Code107- Supply Voltage Cleared
Heating and AC
38 Unknown DTC Unable to clear
Alarm - Unable to clear
16 Signal from airbag
11 Voltage failure during Alarm
34 Interior sensor faulty
10 Voltage failure at terminal 30
60 Central locking limit position
54 Radio receiver defective
33 Interior sensor faulty
When I cheack ABS/PSM 5.7 Panel, I get the following coming up:
Brake distribution
PSM
ABS
I can clear them then turn off engine to clear check light on instrument panel. Any suggestions here? Thanks
Quick Reply: Another ABS PSM problem but also getting Generator failure
