RUF 550hp Conversion Special
From "a lot" to "$5,000 less than a lot" and includes new intake, modified K24 turbos (exchange for yours), exhaust and reprogrammed ECU. However it works extremely well and is worth every penny.
JCM
Check with Ruf on pricing - I believe it is priced in Euros, so it varias a bit, but getting cheaper~! Having the X50 does reduce the price over a standard turbo where you are changing out K16's.
It involves dropping the motor out of the car (which is not a big deal) to get to the top and intall the intake, they change the turbos, the air filter, put on new exhaust, reprogram your ECU for the increase in air flow and to add some fuel and you are off and running - gives you around 550 hp and 580 ft.lbs. of torque - your car will be significantly faster than stock.
Work is generally done at their shop in Dallas, but maybe they will fly a tech to your shop to do the work, but then you would addd the cost of travel and hotel etc... may work out to the same as transport to Dallas. At the same time it would be a good idea to add diverter valves and upgrade the clutch. Your X50 transmission is fine for this power level.
JCM
JCM
From their website "parts" area:
Engine Kit 996 Rturbo 550 bhp, an addition of
130 PS / 96 KW, consisting of two turbos, sports
exhaust with catalytic converters, air filters and fine tuned
engine electronics. Please note that the engine
enhancements can only be performed by the Ruf Team
Power Output (DIN) 405 kW (550 bhp) at 6.000 rpm
Specific Output 113 kW/L (153 bhp/L)
Maximum Torque 780 Nm (575 lb.ft) at 4.000 rpm
Displacement 3.600 cm
Compression Ratio 9.4:1
Turbo/ GT2
Nr.: R96 100 100 51 (Basis 420hp) Incl. Assembly $29,950.00
Nr.: R96 100 100 52 (Basis X50 / GT2) Incl. Assembly $29,950.00
Turbo/ GT2
