Intake Hose - Loose
Intake Hose - Loose
The longer one on the right (if looking at the motor from rear) seems to be sliding out a bit. It will move 4 to 5 mm when the car is driven. What is the fix, new spring clip? Can I just remove the clip and carefully squeeze to tighten it?
H_D
H_D
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
H-D, the hose you are talking about is your bank 2 boost hose. Without seeing what is exactly going on. I would advise you to install a new o-ring and possible a new clip. DO NOT squeeze it!!! Does the car have any mods? How much power are you making. Alot of boost=loose boost hoses sometimes. The hose should positivly engage, audible click.
get a new one from porsche. they have improved the locking mechanism. better yet to improve the appearance of the plain engine compartment replace all of them with an upgraded silicone hose kit. can get them either in red, yellow, and yes even in black.
H_D
look to see if the o-ring blew up around the neck of the hose(the metal part)... when i pushed the hose back in it never clipped all the way..... when pushing the hose back in you will here two snaps when the clips engage...
ps im running the stock hoses at 1.4 bar and they hold well as long as everything is assembled right
tim
tim
tim
tim
Thanks for the insight. I love learning about these cars.
H_D
