Problems with gas pump shutting off when fillin up?
Lately when filling up the gas pump keeps shutting off and it is very hard to fll the tank. What's going on?
That isn't totally uncommon. IIRC it is a fuse that has gone bad and prevents a flapper valve in the tank from operating properly. Check you owners manual for the fuse panel schematic and see if there is a fuse related to the gas fill that has burnt out.....
Been there, done that:
https://rennlist.com/forums/showthre...ferrerid=55151
Check fuse E6.
There's a list of other possible causes, check the link.
Check fuse E6.
