996 Turbo Forum 1999-2005
Radio noise
Old 04-04-2008 | 03:21 AM
seattle_sun's Avatar
seattle_sun
Default Radio noise
Sometimes, I'll unlock the car and when I open the door the radio is making a loud clacking sound. I figure it must be the CD player. It only happens every so often for around 5 seconds and occurs with or without a CD left in the player.
Any ideas?
Old 04-04-2008 | 12:10 PM
manny_g's Avatar
manny_g
this happened to me as well and it was because i had left the cd in the player. once i removed the cd it did not happen again..try disconnecting the radio by removing it from the dash and re-connect.
Old 04-17-2008 | 11:02 PM
babenson's Avatar
babenson
Check you amp connections as well. Mine did this forever until I finally found the source. The connectors were lose.
Old 04-18-2008 | 08:53 PM
taffy320's Avatar
taffy320
Mine is doing it also. Will double check the connections. Thanks for the advice.
Quick Reply: Radio noise
