GIAC
I am confused how to set the GIAC flashloader.
When I connect it to the OBD and press the read button, the read button keep flashing green and doesn't inform what is the current program (stock,pump or race)
If I press the pump button, the pump button flashing light green.
Then I disconnect the Flashloader, turn off ignition, turn on again and connect the flashloader.
I press the read button, the read button keep flashing green.
How should I use the flashloader?
