What is the difference in the 996GT2/GT3 Brake system?
So I ended up grabbing a set of GT3 calipers from a guy who bought them and never used them... Now I'm trying to sort the whole rotor issue out... What are the differences? Are the calipers the same? Are the Rotor "hat" offsets the same? Diameter of rotors the same???
Mike
Mike
If your mounting these to a 996 TT I have a custom set of rotors/hats that work w/ the stock GT3 calipers mounted to the the turbo upright. They have minimal use and are in great shape.
To answer your questions re: the front brakes the rotor diameter is bigger and I believe the offset to be different than that of a turbo.
I've never tried to sell these rotors/hats but believe this to be a perfect match for you. I even have some lightly used Pagid yellows if you're interested.
Email if you're interested rgilhart@cinci.rr.com and I'll be glad to send some pics.
Thanks,
Rick
Thanks,
Rick
Sending you a note now... Consider them "on hold" until we chat... This is exactly what I'm looking for...
Mike
Mike
