Whining noise when cruising at speed ...bad differential?
How far did they take it apart to examine the wheel bearings? My car is making some noise and I can't tell whether its just amplified road noise from the combination of JIC coilovers with solid mounts and 19" wheels/tires. My mechanic checked it as best he could without taking anything apart and said everything looked normal.
My P-dealer also couldn't tell me exactly what was causing the noise without taking things apart but Sharkwerks went on a test drive with me and were so sure it was the wheel bearings and they were right.
I'll tell you this. The noise that I had was unbearable. It didn't matter if the car was in gear or not, clutch depressed or not. It was strictly a function of speed. The faster I drove the louder the noise. And it clearly came from the front of the car.
here you go Jon... I forgot to show you when you picked the car up (go easy on the clutch- no launching!)
Here's a video of it before we fixed the issue:
http://videos.g33kd.net/P1010998.MOV
Right click and save as...
here's what Jon's sound like now
http://videos.g33kd.net/P1010999.MOV
Again right click and save as...
ps. It's going to be tough to drive like a gramma for 300 miles until the new clutch breaks in.
No worries jon, those were some shot bearings! Glad you can enjoy the car again and looks like you got the hang of the clutch as well. Go easy on her for the first few hundred miles
Did you guys replace all the bearings? How did you pinpoint which one it was? Is there anything I can look for without taking anything apart to confirm. The reason I ask is because I am not sure if it is just amplified noise resulting from the JIC coilover mounts and 19" wheel/tire combo or if I really have a problem.
For others who have an increasing noise at speed but do not have a bad bearing, my old tires {Pirelli's} made an increasing noise with speed. I bought new MPS2's and the problem was solved.
