30k mile service
My 2002 996TT is due for its 30k mile service soon. I was just curious if anyone knew what Porsche actually did to the car at that interval and what it cost. I've looked in the manual but its not real clear whats supposed to be done and if its just a fluids change and inspection I'm not sure I want to pay the Porsche service department at the local dealership their premium prices for "routine maintenance work I can do myself.
Thanks in advance for the help.
Jim Parker
Jim Parker
Super Moderator
Needs More Cowbell
Needs More Cowbell
TT/GT2 (996) Maintenance Schedules - Major Maintenance US (to MY02)
Major maintenance after: 30,000, 60,000, 90,000, 120,000 miles etc. (48,000, 96,000, 144,000, 192,000 km etc.)
Diagnosis system: Read out fault memory
Polyrib belt: Check condition
Change the engine oil and oil filter
Replace the spark plugs
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
Underbody panels: visual inspection for completeness, installation and damage
Coolant hoses: Check condition;
Radiators and air inlets at front: Visual inspection for external contamination and blockage;
Coolant: Check the level and antifreeze protection
Air cleaner: Replace the filter element
Particle filter: Replace the filter element
Fuel system: Visual inspection for damage, routing and secure fit of line connections
Power steering: Check the fluid level and bellows
Parking brake: Checking the free play of the parking brake lever
Brake system: Visual inspection of the brake pads and brake discs for wear
Brake hoses and lines: Visual inspection for damage, routing and corrosion. Checking the brake fluid level
Clutch: Check the play and pedal end position
Throttle actuation: Check smooth operation, check the full throttle position with the Tester
Steering gear: Visually inspect the bellows for damage
Tie rod joints: Check the play and dust bellows
Axle joints: Check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
Drive shafts: Perform a visual inspection of the boots for leaks and damage
Exhaust system: Visual inspection for leaks and damage, check suspension
Tires and spare wheel (collapsible wheel): Check the condition and the tire pressure
Check the door locks, lid locks and safety hooks of the front lid to ensure that they are secure and functioning properly:
Check lid lock, front and rear; Check safety hook, front lid; Function test, check door lock; Check door and lid tightening torques
Seat belts: Check function and condition
Vehicle lighting: Check function; All headlights: Check adjustment; Horn: Check operation.
Windscreen wiper/washer system, headlight washer: Check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months.
Electrical equipment as well as warning and indicator lights: Check operation.
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, PSM switch, heating, air-conditioning system and instruments: check operation
Oils, fluids: Visual inspection for leaks
TT/GT2 (996) Maintenance Schedules - Minor Maintenance US (to MY02)
Minor maintenance after: 15,000, 45,000, 75,000, 105,000 miles etc. (24,000, 72,000, 120,000, 168,000 km etc.)
Change engine oil
Brake hoses and lines: Visual inspection for damage, routing and corrosion. Check brake fluid level
Tires and spare wheel: Check the condition and the tire pressure
All other electrical equipment as well as warning and indicator lights: check operation
Test drive:
Important Notes:
· It is extremely important to check the air cleaner (and replace it if necessary) each time minor maintenace is carried out.
· On vehicles with annual mileages of less than 9,000 miles (15,000 km), an annual maintenance must be carried out once a year.
· Maintenance with oil filter change must be carried out at least every 2 years according to the mileage, if the mileage for a major maintenance has not already been reached.
· For an annual mileage of more than 9,000 miles (15,000 km) it is recommended to carry out the next maintenance as soon as possible.
· The term "checking" includes all necessary subsequent work such as adjusting, readjusting, correcting and topping up, but does not include repairing, replacing and reconditioning parts or assemblies.
TT/GT2 (996) Maintenance Schedules - Addititional Maintenance US
Additional maintenance, replacing spark plugs
911 Turbo/ GT2 every 30,000 miles (48,000 km)
Additional maintenance every 60,000 miles (96,000 km) OK
Important Note:
· It is recommended to replace the fuel filter every 60,000 miles (96,000 km).
Replace Polyrib belt
Additional maintenance every 90,000 miles (144,000 km) OK
Manual transmission: change oil
Automatic transmission: change ATF and ATF filter
Automatic transmission: change oil in final drive
Final drive, front: change oil
Maintenance every 2 years OK
Change brake fluid (use only original Porsche brake fluid)
Check roll-over protection system (911 Turbo Cabriolet as of MY04)
Condition report - preparing long-life guarantee
Form WKD 444 010 02 German
Form WKD 444 020 02 English
Form WKD 444 021 02 US English
Form WKD 444 030 02 French
Form WKD 444 031 02 French-Canadian
Form WKD 444 040 02 Italian
Form WKD 444 050 02 Spanish
Form WKD 444 091 02 Dutch
Maintenance after 4, 8, 10 then every 2 years OK
Inspect air bag system
Mounting of assemblies and running gear: Visual inspection of all rubber mounts for damage
TT/GT2 (996) Maintenance Schedules - Annual Maintenance US
Annual maintenance
Vehicle underside and engine compartment: Visual inspection for leaks (oils and fluids)and abrasion (lines and hoses)
Engine: Check oil level
Track rod joints: Check the play and dust bellows
Axle joints: Check the play and visually inspect the dust bellows for damage
Test drive:
Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, PSM switch, heating, air−conditioning system and instruments: check operation
Important Notes:
Test drive:
Change engine oil
Test drive:
Important Notes:
Important Note:
Annual maintenance
Test drive:
Important Notes:
