996 Turbo Forum 1999-2005
Turbo cool down period - How long??
Old 05-25-2007, 03:23 PM
  #31
MGS996
MGS996's Avatar
All great news from a tax relief standpoint…….my future stage 2 Hybrid package is now deemed as repair/maintenance!!
Old 05-25-2007, 03:49 PM
  #32
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Originally Posted by jcb-memphis
I have moved to 60s for simple driving and 120s for anything with boost in the last 5 minutes, even 0.1bar. Just what I am doing. If I tracked, I probably would go 4-5minutes/a lap too, but I don't.
If the turbos did not fail, people like Kevin would have a lot less business. They fail. I have seen Audi's go up, Saabs, one 930's.....so in time with abuse, these will too. It is probably a bell curve...some peoples' will fail with good care and others will never fail with abuse. I suspect Porsche knows....
Just my opinion. I just listen to music.
JB
JB, Got normal photos of the car in your avatar? If so, can you email them to my account? wachuko67@aim.com Thank you!
Old 05-25-2007, 04:50 PM
  #33
porschedude996TT
porschedude996TT's Avatar
Originally Posted by Dock
Our turbos run ~150,000 rpm at full boost, and the maximum designed rpm is 170,000.
Hey Dock, I can believe those numbers. With the Aircraft Turbo's, they where limited to about 60,000 by design as part of the Type Certificate. The Turbo's on aircraft are larger in diameter and output. More than the engine can handle because they are also pressurize the cabin. The FAA also worried about the turbine section coming apart at high RPM and the housing was thicker to prevent penetration should the turbine wheel go Omni-directional.
Quick Reply: Turbo cool down period - How long??
