Went to the Drag Strip again
Originally Posted by Q
700hp
mid 10's certainly sounds right from 700hp![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I found the best 60ft results from the 993TT came from driving off the line normally at 2000rpm.....
That gave consistent 1.9 60ft times
![](http://www.qplanet.org/q/993/993_119T.jpg)
The question remains, where is the rest of your time going ???
How much wheelspin are you experiencing once off the line ?
Whyich tyres ?
Tyre pressures ?
Any pics of the car ?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Whyich tyres ?
Tyre pressures ?
It looks a little bit different with the Aero lip and black centercaps and lowered just a bit more.
![](http://www.darkstarnetworksllc.net/turbo/1IMG_0953.jpg)
Originally Posted by HSW
Gareeb, were your runs on pump or race fuel? And how much boost were you running? Thanks.
Car looks great!
Car looks great!
3/4's of a tank
Gareeb,
Congrats and if you dont mind me asking about your car's specifics as my car is at Protomotive
as we speak?
Do you have hard piping from turbos to intercoolers and Protomotive Custom Intercoolers?
Do you have custom Y pipe with larger throttle body?
Do you have K24/18g turbos with upgraded waste gate actuators?
Do you have upgraded fuel pumps and larger fuel injectors?
(in addition to the obvious upgraded fuel pressure regulator)
thanks in advance!!
Marty K.
as we speak?
thanks in advance!!
Marty K.
Originally Posted by mclaren55
Maybe you guys just need more practice. ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
We use up most of our traction just hanging onto this damn planet...
Originally Posted by Woodster
Gareeb,
as we speak?
thanks in advance!!
Marty K.
as we speak?
thanks in advance!!
Marty K.
Gareeb,
Did you buy Scott's set-up?
Scott had everything I listed EXCEPT larger throttle body.
Your car should really fly! Good luck with future runs.
Marty K.
Marty K.
Gareeb,
Marty K.
Marty K.
Gareeb,
Marty K.
Marty K.
