996 Turbo Forum 1999-2005
negative Camber
Old May 2, 2007 | 08:54 PM
rlevy996's Avatar
rlevy996
Question negative Camber
What is stock negative camber on 996tt. How much negative camber can one get on stock supension.
Old May 3, 2007 | 12:33 PM
GreggT's Avatar
GreggT
My records show .3 to -.3 front and -1.2 to -1.7 rear as OE default for US spec.
I don't have what the limet for stock suspension is.....but it's beyond these ranges for sure.
Old May 4, 2007 | 01:34 AM
Duane993's Avatar
Duane993
Lower the car and you can get up to 2 degree negative camber front and back no problem
Old May 4, 2007 | 09:27 AM
GreggT's Avatar
GreggT
Yep....and lower the car some more and you will have more (than you want )
Old May 4, 2007 | 12:51 PM
jrok's Avatar
jrok
I'm not sure how you could get -2 in the front without cutting some metal.
My settings would indicate your records are right because I was able to get about 1 degree more than stock delivery without any modification. I have the full RUF suspension which is basically a custom valved PSS9, springs and rear sway bar. The car is lowered down practically onto the tires because it is primarily my track car. With the front top mounts pushed all the way in and the lower adjustment all the way out I was able to get -1.3/-1.4 in the front and -2.4/-2.6 in the rear.
Old May 4, 2007 | 01:31 PM
GreggT's Avatar
GreggT
Jerry.....nice cars.
I think of your part of the country every year at this time cause we always used to come down for the Porsche Derby........great fun.
Intstead, we will raise a Mint Julip in your direction this weekend......cheers.
Old May 4, 2007 | 04:27 PM
jrok's Avatar
jrok
Thanks, and Here, Here, to the Mint Julips! Yes, it's Derby Weekend here. You can easily tell because there's even more people on the roads that don't know how to drive. Wish you were here... Cheers to you.
