X73 Suspension Question
If I order the X73 suspension kit from the dealership will I need anything else to install this on my 2001 996 turbo. I'm assuming everything I would need for the install is included in the kit but someone let me know if I am way off. Thanks.
Ignacio
Ignacio
No everthing`s all there. Need a spring compressor to remove the fronts. And I had to disconnect the front axles at the differential to get enough clearance to remove the old front suspension. Some say you don`t have to, but I could not see any way around it.
One last question before I take the plunge. Can some please list all the parts and hopefully the part numbers that should be included in the kit when bought from a dealership. Thanks.
