Need opinions on these MOMO shift knobs
A little more research revealed the input opening on the bottom of the MOMO ***** is 9/16" diameter. Does anyone know the dimensions of the square 996 shifter?
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by KPV:
<strong>
Lydon,
The tires are Yokohama AVS Sports. They are the only 19 inch tires available in that size. You can obtain them from Gert at Carnewal.
<a href="http://www.carnewal-europe.com/main.htm" target="_blank">http://www.carnewal-europe.com/main.htm</a>
Click on Wheels and you should see them.
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Continental also makes a 19" tire in that size. Gert may be able to get that one too. If not, try Matt at ByDesign 310-559-9670 -- he has them available.
<strong>
Lydon,
Double check and see if the **** will fit. I am not sure if the TT has the same stupid "butterknife" top the boxster does.... if it does you may have to get the top part of the rod milled round. I did when I was installing a Ruf 993 shift **** on my boxster (no 986 one available in that style).... gave me a good excuse to by a B&M short shift kit.
cheers,
Rage
cheers,
Rage
Rage,
I was planning to get the short shifter but what benefit will that serve with regard to the ****? I thought the short shifters have the "butterknife" attachment also.
KPV,
No benefit actually other than not having the car out of commission. Once I received the B&M I took it directly over to the machine shop to have it milled round.
cheers,
Rage
cheers,
Rage
Rage,
I contacted MOMO today and they told me their ***** attach with several set screws. They also said the insert diameter of the **** is 9/16". Do you know the dimensions of the short shifter?
Unfortunately I have milled mine down already. I have a MOMO on my BMW that I can remove and measure. I am pretty sure that if the TT has the butterknife attatchment that It will not fit... don't quote me on that. I would ask them if they have installed the on a 996tt just to be safe.
Cheers,
Rage
Cheers,
Rage
