can catalytic converters be swapped out without..
changing the entire exhaust? For example, could high-flow Cargraphic cats be used to replace stock 996TT cats on an X50? Thanks in advance.
Not sure about the Cargraphic, but S CARGO modifies the stock exhaust, and puts 100cell race cats in it. You should call Rob King at SCargo
<a href="http://www.scargoracing.com" target="_blank">http://www.scargoracing.com</a>
You can change out the cats on any aftermarket system. The stock system has the cats welded to the muffler. Just removed the stock system and replaced with a B&B.
