DPI BRake recirculators
Talked to their tech guy Randy. Very helpful and knowledgeable people. The Brake recirculator needs 2 caliper crossover tubes that attach across top of the calipers. They custom fit them, 48 hr turnaround $45/side. Cost of Unit $158.00, you just need to do the fronts.
For anyone curious about the these. They continually recirculate brake fluid through the calipers (this doesn't happen with a stock system) so fresh, cooler brake fluid is pushed through with every brake application.
<a href="http://dpiracingproducts.com/productdet.php?producttype=Brake_Recirculator" target="_blank">DPI Racing Products</a>
